Format Brush
moonflea
Format Brush
Post by moonflea »
In version 1.0.5.89 & 1.0.5.90:<br>The format brush does not work properly/intuitively - try it out for yourself. This is why I decided to look at Atlantis in the first place - I got tired of second guessing my word processor and wanted something that worked consistently and simply. The search continues...<br><br> ??? :-/
Re: Format Brush
The Atlantis Format Brush works exactly as it was supposed to work:<br>http://www.rssol.com/en/html/chronicl/atlant1x/1_0_3.htm<br><br>You may have your own expectations and your own point of view.
moonflea
Re: Format Brush
Post by moonflea »
::) Oops - my mistake - I confused the format brush with the copy font format options (yes, I know, read the manual BEFORE complaining :)<br><br>Keep up the good work.
