"Open With Atlantis WP" in context menu...
zubina
Post by zubina »
I would really like to see an "open with Atlantis WP" in Windows Explorer's right click/context menu, in your next upgrade. As I use MS Word in conjunction with Atlantis WP, a right click context menu extension will really be helpful for a prolific word processor like me. Thanks you!
Zubina
Applications do not add themselves to the "Open with" list. Windows Explorer does.
Please right-click your document file in Windows Explorer. Choose the "Open With | Choose Program..." command from the menu. Choose Atlantis from the list. Next time you right-click a document of this type, Atlantis should be offered directly under the "Open With" menu.
zubina
RE: Open With Atlantis WP...
Post by zubina »
Thank you.
Zubina
