I'd like to propose two very minor improvements to Atlantis:
(1) There doesn't seem to be a menu shortcut key for the 'View Documents Side by Side' feature in the View menu.
(2) There doesn't seem to be an easy way to insert a symbol in the 'Find/Replace' dialogue box, as one can a special character.
Many thanks
Rob
Two minor feature requests
(1) The "View Side by Side" command is offered under the "Windows" menu. It is a more natural place for this command because this command deals with entire windows, not with components of the active document window.
(2) Sorry, but the edit boxes of the "Find/Replace" dialog of Atlantis cannot offer all the capabilities of the "document editor" of Atlantis (I mean the commands that can be used in the document window of Atlantis when you edit a document). But you can insert the desired character to any document in Atlantis through the "Insert | Symbol..." menu command, then copy/paste it to the "Find/Replace" dialog.
Hi Rob,
You can assign a keyboard shortcut to the “View Side by Side” command in this way:
1. Click “Tools | Hot Keys…”
2. Select “All Commands” as a category.
3. Click in the “Commands” window.
4. Type “v”.
5. Scroll the “Commands” window until you reach “View Side by Side With…”
6. Click in the “New hot key” box.
7. Type any suitable hot key.
8. OK out of the dialog.
4. Type “v”.
