error when calculating totals
Peter
Post by Peter »
When I want to calculate totals using Alt-Clt-Sft keys I get an error message: Calculation error: Unknown constant "5.0 6.0 7.0" These are the numbers I tried to add.
What I am doing wrong? I use Atlantis Nova 1.0.0.70
Thanks for the help
Peter
Atlantis Nova does not calculate totals. It calculates arithmetical expressions. Type "5.0+6.0+7.0" in your document, then use the "Calculate" command.
Peter
Error when calculating totals
Post by Peter »
Thank you for the advise. I can live with it, but would be helpful to sum a column (even if only on the clipboard).
Any chance to get it in a future update?
Otherwise I enjoy using Atlantis, it does all I need from a word-processor (at least until now). It opens fast like a text editor, but its capabilities are much better.
Thank you for offering it free.
Peter
The full version of Atlantis Word Processor can sum a column of numbers. Please click the following link for details:
http://www.atlantiswordprocessor.com/en ... ps_010.htm
I know that you are interested in the freeware version of Atlantis. But the problem is that we do not add new features to Atlantis Nova since 2001. Atlantis Nova is a quite old software with a limited set of features. I am sorry.
