Do Colour Schemes
Re: Do Colour Schemes
Your friend will not see your color scheme. Color Scheme is a component of your local settings used for displaying all your documents. Like the Color Scheme of Windows that is applied to all applications.<br><br>About "sending" you current color scheme to a friend. Hmm... If you and your friend are familiar with the RegEdit.exe, you could do the following:<br><br>a) close Atlantis,<br>b) send the contents of the HKEY_CURRENT_USER\Software\Rising Sun Solutions, Inc.\Atlantis.1_x\ColorScheme\Colors registry key to your friend,<br>c) ask your friend to paste this contents to the same registry key of his/her computer.<br><br>Currently this is the only way...<br><br>By the way, if you think that you have created a new interesting color scheme, you could send the contents of the above registry key (accompanied with your suggested title for this color scheme) to the betatesting@rssol.com. It would be considered for inclusion to the set of predefined Atlantis color schemes for future releases.
Max_Quordlepleen
Do Colour Schemes
Post by Max_Quordlepleen »
What I mean is this: If I select a colour scheme for a document in Atlantis, save it, and send that document to a friend who also has Ocean Mind, will they see my colour scheme? If not, is there any way to achieve this? Having got my friend into the habit of emailing by attaching CODs, she is now missing her stationery. I it were possible to insert jpegs as background, to  be written over, that would achieve the same end, but making colour schemes "stick" would be just as handy.
Salaam alaikum, noho ora mai
