I use the squeeze button frequently, but I'd love to have a stretch button too. Not only would it be handy for the times when I've shrunk and saved the file and figure out a day later that I really didn't want to do that, but it would also be great when I need to have a certain page count and need to increase the length of the text in the document.
Have you tried the "Grow font size" command of Atlantis? Its default hot key is Ctrl+]. Just press Ctrl+A to "select all", then press Ctrl+] to "grow font size". This would automatically "stretch" your document.
I didn't know about that command! Thank you so much. (I just tried it, and it takes the font up one whole size, whereas the squeeze button moves in half-font increments . . . but I can stretch and then squeeze, and it should work great!)
