Words hang
medion
Words hang
Post by medion »
Hi, since updating to the new version of Atlantis, I have noticed that when typing, the first few words do not appear on screen for a few seconds. As an example if I write Dear(Dea) will appear then it will take a few seconds for the rest of the word and the following words to appear.
Thanks
medion
Post by medion »
I have had to disable power type, it was taking 4 seconds before I could type after the first 3 letters showed on screen.
Thanks.
The Power Type of Atlantis Word Processor 1.6.2 (and higher) groups inflected forms of words within the popup list of suggestions. The corresponding module that deals with inflected forms, is quite slow to load. So this delay is not caused by the Power Type itself.
The upcoming version of Atlantis Word Processor 1.6.4 (it should be available for betatesting in the next few days) will load the module with inflected forms in a less "noticeable" way. You will not experience such delays anymore.
medion
Post by medion »
Thank you Admin.
