Where should I save atlantis.ini?
Max_Quordlepleen
- Contact:
Whenver I make changes to my settings, and select "save to file" the dialogue box that opens wants to save the .ini file in whichever folder I happen to have opened last. Where should I save the .ini file?
Salaam alaikum, noho ora mai
Re: Where should I save atlantis.ini?
This INI file could be used for "installing" Atlantis Ocean Mind to a floppy disk (read the Help for details). The settings are automatically saved to the Registry of Windows each time you close Atlantis.
Max_Quordlepleen
- Contact:
Thank you.
