Overused Words
Peter Merton
Overused Words
Post by Peter Merton »
Don't do what I did. At the end of a 16 page document, I activated Overused words. The program locks up, and then closes Atlantis. Rather start Overused Words from the beginning of the document only.
It would be useful if sections of a document could be highlighted and then checked by Overused Words, then having reached the end of a long document, just the last page can be checked.
This is not a problem on documents of just a few pages.
Regards, Peter
Hi Peter,
This is not happening on my system. If there aren’t any privacy concerns, could you please send your document to support@AtlantisWordProcessing.com?
Thanks.
Peter Merton
Hi Robert,
Unfortunatley for privacy reasons I can't send the document to you. The same problem occurs on a 6 page document. But as long as I remember to start Overused Words only from the beginning of the document, then there is no problem.
Regards, Peter.
Hi Peter,
Is the 6-page document also “private”? Maybe you could find a “non-private” document where this occurs too? If you can find one, please send it to us and describe exactly what you did before the problem occurred. Starting the Overused Words feature at any point near the end of a document is not enough to create any problem on my system. Either this is specific to the kind of documents you have, or to your current Atlantis settings. Could you please also create an “Atlantis.ini” file (“Tools | Options > Save to File…”) and send it too?
Thanks.
Peter, thanks for the document and your settings file. This bug will be fixed in any next release of Atlantis Word Processor.
Thanks for reporting this bug.
Peter Merton
Hi Robert,
Thanks for the new file. Everything works fine now. Much appreciated. And thanks for your trouble. Regards, Peter.
