I create my story outline in another program and want to write the story in Atlantis. Problem is though, that I cannot export from that programa rtf or text files, I can do a print as pdf though. But is there a way to get it afterwards into Atlantis?
André
Is it possible to open or import pdf?
Andremusic
- Contact:
Keep on Writing!
Copy from PDFs
Hi André,
Atlantis cannot open PDFs. But you can open PDFs in a PDF Reader, select all text, then do a copy/paste into Atlantis.
If you are using Adobe Reader 9, you have a convenient “Edit | Copy File to Clipboard” command.
