Unable to open docs on doubleclicking in windows explorer
rod
Post by rod »
Hi - I went into windows explorer and selected Tools>Folder option and change all docs to be opened by Portable Atlantis' exe but when i doubleclick on any doc documents, it straightaway opens up a .rtf file instead of the file I doubleclicked.
Is there a setting in the .ini or anywhere I need to specify options in order for Atlantis to open up the DOC document I double-clicked rather than it opening up a predefined template or rtf file?
:cry:
What do you mean by “Portable Atlantis”? Is it the U3 version? Or did you install standard Atlantis on a standard USB key?
When you double-click a “.doc” file, is it in a folder on your PC, or on the USB key?
