Highliting
medion
Highliting
Post by medion »
Hello.
I give lectures, and would like to use Atlantis for item reminders. Is there a way to highlight the next line instead of using the mouse or touch pad on my notebook? A single key not a combination of keys. (Atlantis help used as example only)
Thanks.
Hi Medion,
There is no single key shortcut but
"Shift + Up" will highlight from current cursor position, to one line up.
"Shift + Down" will highlight from current cursor position, to one line down.
Also you could assign a custom hot key to the "Select current line" command (Tools | Hot Keys... > All Commands > "Select current line"). The default hot key is "Ctrl+K,L". As a single key shortcut, you could use any available function key (F1/F2/F3/etc).
medion
Post by medion »
Hi Robert.
Thanks.
