I would like to place the toolbars, where they take the least place. For example after (beside) each other. In favour of the place for the texts.
Thanks in advance.
Vincent van Gool, Amsterdam
toolbars; optimal place
- Doc02.rtf
- (32.46 KiB) Downloaded 1157 times
Hi Vincent,
If you mean to say that you want all or most of the toolbar buttons to be on the same line, you can use the “Tools | Toolbars…” dialog to shift the buttons around until you get any suitable layout. It does not matter which toolbar (all) the buttons are on. You have got enough free screen space. Note that the “Tools | Toolbars…” dialog supports drag & drop.
Hope that help.
Hope that help.
