greek letters
mariosp
greek letters
Post by mariosp »
I mostly use Atlantis in greek language documents. When opening a document saved by another word processing program, the greek letters "μ" and "β" are somewhat "corrupted", i.e. different (they are not recognized also by spell checkers...) The letters that Atlantis use are "ß" and "µ". If they appear identical here, I attach a doc file (the same goes on with "rtf" files, actually with all files, when I copy [from Atlantis] and paste text [in Atlantis again] from clipboard "As Environment"...)
Thanks in advance.
test1.doc
(19 KiB) Downloaded 996 times
Atlantis incorrectly converts these two Greek letters from Unicode to ANSI. This will be fixed in the next release of Atlantis. Thanks for reporting.
mariosp
Post by mariosp »
Thank you.
