Printing
felix
Printing
Post by felix »
With other word processors I have used everything I print comes out in normal full page size, but since I started using Atlantis my prints cover only about 1/4 of the normal 8 1/2 x 11 page. I have tried changing the settings prior to printing but to no avail. What am I doing wrong?
Please check settings in the "File | Print..." dialog of your Atlantis. Please also click the "Properties..." button in the "File | Print..." dialog of Atlantis, and check the proprietary options of your printer that might lead to such a printing result.
If the problem persists, please click the "Start > Run..." command of the Windows Taskbar, and run the following command-line in your Windows (please use copy/paste):
"C:\Program Files\Atlantis\Atlantis.exe" -DontLoadSettings -DontSaveSettings
This would launch an instance of Atlantis with the default settings. Then try printing your document.
felix
Post by felix »
Thank you for helping me correct my printing issue which responded to your suggestion to check Properties @ File/print, where I found I inadvertently set printing size @57% of full page. Problem solved; good work. Thanx again
