Turning off underline spell check
swhi1106
Post by swhi1106 »
<br>Is there a easy way to toggle underline spell check for the current document.<br><br>It would be great if this could be done from the toolbar.<br><br>
Re: Turning off underline spell check
There are multiple ways. The simplest ways are the following:<br><br>a) right-click the Spellcheck Status bar icon, then choose a corresponding command from the popup menu,<br><br>b) right-click any word marked with a wavy underline, then choose the Spelling Options command from the popup menu.
