How to Remove Spaced Pages and Automatic Spell Check?
ghenko
Post by ghenko »
How do I remove the small spaces between pages so that it can just be a dotted line to indicate separate pages instead (or if not possible, how about no indication of separate pages)? Also, how can I turn off spell check when I'm typing something?
Sorry, but the present version of Atlantis Word Processor does not have the so called "Normal" view mode. Atlantis displays documents only in the "Page layout" view mode (ie with "interpage breaks").
To disable the "Spellcheck As-You-Type", please uncheck the "Spellcheck As-You-Type" box on the "Spellcheck" tab of the "Tools | Options..." dialog of Atlantis.
