File opening question
Peter Merton
Post by Peter Merton »
Often I need to open a file which has a word in the filename common to a number of files. Let’s say the word “agenda”. These files will be scattered in My Documents depending on the words in the filename before “agenda”. If I type *agenda* on the File name line Atlantis lists the correct files, but comes up with an error message saying “Cannot open file C\:MyDocuments\etc\etc\*agenda*”. But it has listed the files perfectly. So is it possible for it not to show the error message?
It is a glitch with the Preview pane of the "Open document" dialog of Atlantis. It will be fixed in any next release of Atlantis Word Processor.
Thanks for reporting this.
Peter Merton
File Opening Question
Thank you. It works perfectly. This feature is so useful and with the Atlantis preview screen is even better because I can browse each file, find the right one and then double click it or click open. Another winner for Atlantis. Best wishes to all of you. :lol:
