Funky Spellchecking
mikespeir
Funky Spellchecking
Post by mikespeir »
Occasionally there will be a word I've added to the dictionary during spellchecking that will continue to be flagged as unrecognized. Even if I right-click on it and select the very word again from the list of suggestions it remains underlined.
I'm attaching a paragraph that demonstrates the problem.
Problem.rtf
The word "rudten" is the problem here.
(1.66 KiB) Downloaded 891 times
I cannot reproduce any problem. Could you please send your custom dictionary (I mean the userdicen.tlx file from the "C:\Program Files\Atlantis\Spellcheck\Lex\" folder)? You could attach it to your reply, or email it as attachment to support@AtlantisWordProcessor.com.
mikespeir
Spellcheck Problem
Post by mikespeir »
It's attached.
mikespeir
Spellcheck Problem
Post by mikespeir »
Well, good grief! Now it's not doing it. I don't know what's going on.
Do you mean that you emailed your custom dictionary to support@AtlantisWordProcessor.com? It seems that we received no email from you. By the way, when you need to send us a file by email, please ZIP it before attaching to your email message.
mikespeir
Spellcheck Problem
Post by mikespeir »
I'll try again. Like I said, though, it's not doing it now. I'm sure I wasn't making a mistake before. I had manually spellchecked the document several times.
userdicen.zip
(1.08 KiB) Downloaded 988 times
Thanks for the dictionary file.
A note regarding word capitalization. Your dictionary includes two case patterns of the same word: Rudten and rudten. This might lead to collisions. Only the lowest valid case pattern should be included in the dictionary. If "rudten" is a possible case pattern of your word, its capitalized version "Rudten" should be removed from the dictionary. Otherwise the lowercase version "rudten" should be removed. To edit your dictionary, please right-click any red-underlined word in your document, and choose the "Edit Dictionary..." command from the menu.
mikespeir
Spellcheck Problem
Post by mikespeir »
Done. Thanks for your help.
