I am making a lot of use of columns in Atlantis as I find them a very good substitute for tables in the type of work I am doing.
However, I find that changing from one column to the next is a slow having to use the mouse. Is there a way via the keyboard to change between columns? It would be extremely useful and far quicker.
I’m afraid a shortcut to move from one column to the next is not possible. But you could use a column break (“Ctrl+Shift+Enter”) to move to the next column when you have finished typing in one.
Hope this helps.
