New Files Naming
acant05
New Files Naming
Post by acant05 »
Each time I create a new file a new number is appended whether the previous one was saved. Can I reset this count someway? I am now up to Doc77.rtf I would like to use "Doc01" until a file is saved by that name. Thanks.
Blessings,
Al Cantley
Please uncheck the "Continuous numeration" box on the "General" tab of the "Tools | Options..." dialog. After a restart, Atlantis will use "Doc01.rtf" as a name for your first new document.
Leopoldus
Post by Leopoldus »
Hi!
My wash regards new documents naming/numberring too, but it's a bit another. Is it possible to increase the loop of numbers sequence used as a final part of a new document name? Now it is 01-100, but I'd need something like 01-999.
Thanks!
Sorry, we cannot make this change to the standard version of Atlantis Word Processor.
But if you like, we could compile and send you a custom edition of the executable file of Atlantis that would work in the way you need.
Leopoldus
Post by Leopoldus »
Thank you, but it is not SO critical for me, can live without it :wink:
However I please you consider once more adding this option to the standard version. I suppose, that many oher user might wish it as well.
