Character bug?
Lambert John
Character bug?
I like to write "C/O:" to indicate "in care of." However, in Atlantis, whenever I type the "C" then the forward slash key, the "C" is immediately replaced with a cents symbol. I'd be interested to know if it's just my computer, or if this happens with everyone out there. And if it does, why? Is there some setting I need to toggle to keep this from happening? Thanks.
Re: Cents Sign
Greetings--
By default, the Atlantis AutoCorrect function includes the following replacement pair (see screen capture below):
c/ -- ¢
To remove this particular replacement pair, select it in the "Tools | AutoCorrect Options..." dialog, then press the "Delete" button. OK out of the dialog.
c/ -- ¢
- Cents Sign.png (9.92 KiB) Viewed 6640 times
