shortcuts
medion
shortcuts
Post by medion »
I'm sure i have seen in Atlantis that there is a way to perform shortcuts. eg. full address etc. By using one or two keystrokes.
Many thanks.
Sorry, but Atlantis does not have a command that inserts "full address".
But you could add your "full address" to the Atlantis Clip Library as a new clip. Any clip can be inserted to the active document in Atlantis with a few keystrokes.
Here is how to proceed:
1) If the Atlantis Control Board is not displaying, press F6 to show it, or choose the "View | Control Board" menu command, or click the dedicated toolbar button: Image.
2) Switch to the "Clip Library" panel of the Control Board (click the "Clip Library" button at the top of the Atlantis Control Board: Image).
3) Type the full address in the active document, and select the address with the mouse or keyboard.
4) Click the "Add document selection to Clip Library" button Image at the bottom of the Clip Library panel of the Control Board. Alternatively right-click the document selection, and choose the "Add to Clip Library…" menu command.
The "Add to Clip Library" dialog would popup up.
5) Specify the desired name for your new clip ("Full address", or something like this), then click "Save". Note that if your document selection does not include font formatting that should be saved to a new clip, it is preferable to save clip as a plain text file – just choose the corresponding document format at the bottom of the "Add to Clip Library" dialog.
6) Click the "Clip Library options" button Image at the bottom of the Clip Library panel of the Control Board, and make sure that the "Replace clip names As-You-Type" box is checked. Then click OK.
7) Click anywhere in your document, and type asterisk (*) plus the first three letters of the desired clip name (in our case, type "*ful"). Atlantis would display a list of clips whose names begin with "ful". You could keep typing the clip name if the list of suggested clips includes multiple items. Alternatively you could use the arrow keys to choose the desired clip manually. Then just press Enter to insert the clip.
Re: shortcuts
Greetings--
You could also create an AutoCorrect Replacement entry ("Tools | AutoCorrect Options").
For example, you could ask Atlantis to systematically replace "Atlant" with http://www.atlantiswordprocessor.com
medion
Post by medion »
Thank you both very much indeed.
