Couple of newbie questions
jacatone
Post by jacatone »
I've disabled the sounds in Atlantis but would like to keep the typing writer sounds. Which ones would I make active to do that? Also, Atlantis automatically opens on the last document I was working on when I fire it up. How do I disable that feature? Thanks.
Re: typing sounds
Greetings--
Enable the "Press Key" event in the "Tools | Sounds..." dialog.
Bring up the "Tools | Options..." dialog, click to display the "Load / Save" tab, uncheck "Reload open documents at startup".
