Zip
Zip
Post by 1953 »
I am interested to know if when a zip file is sent as an email.<br>a. does Atlantis zip the file or does it use the zip program installed on the computer, and if there is no zip program installed would the file be sent as a zip.<br>b. if there is no zip program installed would Atlantis be able to read the zip file. If you understand what I mean.
Re: Zip
Atlantis uses its own Zip routines to create Zip files. No additional utility (like WinZip) required.<br><br>Atlantis does not "read" Zip files. If you are going to send a Zip file to somebody, that person should have a Zip utility (WinZip or similar).
