Support for other email clients?
Re: Support for other email clients?
Hey Mex!<br><br>What exactly did you do to get Atlantis to work with Pegasus? PMail has been my fav for years...downloading the MAPI enabled version as I type.<br><br>TIA, <br><br>steve
- Contact:
<br>
<br><br>Hi Steve - nice to hear from another Atlantis/Pegasus combo user. Remember when you run WPMMAPI.exe, to enable MAPI, that you must select simple MAPI for Atlantis and Pegasus to work together. Then, just follow the advice that admin gave here - Create a temp file to attach. The easiest way to do this is just to hit Ctrl-S to save the open document, then hit the space bar to create a modified temp file. I do this now whenever I want to send something straight from Atlantis, and it works like a charm. I hope this helps.steve wrote:<br>Hey Mex!<br><br>What exactly did you do to get Atlantis to work with Pegasus? PMail has been my fav for years...downloading the MAPI enabled version as I type.<br><br>TIA, <br><br>steve<br>
Salaam alaikum, noho ora mai
