Could you recall which "earlier version"?Guest wrote: In an earlier version of Atlantis I had no problem whatsoever I clicked on print and clicked on fax printer and sent the fax (no problem at all )
Fax
Guest
Please download the following zip file:
{This file is not available on the server anymore.
The functionality mentioned above is available in the standard version of Atlantis.}
Please unpack its contents (“Atlantis.exe”) to the home folder of Atlantis (by default, “C:\Program Files\Atlantis”). Then launch Atlantis, and try sending faxes. Is there still the same problem on your PC?
Guest
No still the same. Atlantis freezes when I use Mighty fax's address book to insert Fax number. I still have to minimize to system tray before I can close Atlantis. Mighty fax has said it is not their software. This only happens with Atlantis.admin wrote: Please download the following zip file:
Guest
This is a detailed description.
I write the text in Atlantis.
I click on print.
Mighty fax printer
OK
Mighty fax printer Driver appears
I click on Phone Book
Insert recipient
Insert Subject
THEN ATLANTIS FREEZES
I have to minimize to system tray then send fax. Open up Atlantis from system tray and then I am able to close Atlantis.
Many thanks.
I click on print.
Mighty fax printer
OK
Insert recipient
Insert Subject
Many thanks.
Re: Fax Printing Problem
Hi, Guest!Guest wrote: This is a detailed description.
I click on print.
Mighty fax printer
OK
Insert recipient
Insert Subject
Many thanks.
What exactly do you mean by "THEN ATLANTIS FREEZES"?
If Atlantis is "frozen" as you say, how can you "minimize [Atlantis] to system tray"?
Normally, when an application "freezes" (locks up), no commands are available.
Which commands are available when your Atlantis is "frozen"?
Which commands are unavailable when your Atlantis is "frozen"?
Guest
Guest
