Issues with portable mode
atlanta
Post by atlanta »
Portable mode was a prerequisite for my buying decision. I followed the instructions and it runs fine from my USB stick.
However, on some host machines it leaves data on the logged-on user account. I have to manually clean up after Atlantis and always remember to sync that stuff back to my stick. Then at home, when I sync it to my own user account of the installed version, there are still things missing. Cannot figure out where it stores certain settings, such as, say, Color Schemes?
Have also tried to copy the whole portable folder back and forth, but that makes no difference. Some things always end up getting lost upon syncing from stick to hard drive and back again.
In addition, some paths seem to get hard-wired. How do I make Atlantis save my Favorites-links in a portable fashion?
Have you tried to import settings back through the “Load from File…” button in “Tools | Options…” (“General” tab)? Of course, the file to use is the “Atlantis.ini” file located on the USB stick.
atlanta
Post by atlanta »
Thank you Robert,
works nicely. An additional chore after each sync, browsing for the ini-file etc. - but I can live with that.
Concerning the other issues - here's what I found out:
Atlantis has problems running from encrypted volumes and also from external drives that are plugged into docking bays, where the drive shows up as a regular drive letter, not flagged as "removable". Well, "problems" is the wrong word, it works nicely, but without telling you it will leave residues on the host computer and behave as if it were installed, which is not the case.
Any ideas what I am doing wrong? Workarounds? Alternatives?
Thanks in advance.
External drives that are plugged into docking bays are configured as fixed disks by Windows. As far as I know, nothing flags them as removable drives. I am afraid Atlantis cannot second-guess Windows about this…
atlanta
Post by atlanta »
Thanks again, Robert.
This is bad news. So bad that it should be mentioned on the website, because it is very unusual. I own quite a lot of portable software, they all install into a folder of my choice, and this tells the software to use relative paths and store all settings in subfolders. Easy to sync the whole enchilada in one go, without additional launches of the software, "Load ini-file" etc etc
What am I to do now?
1) Install my license on foreign machines - not legal and not always possible, due to restricted user rights
2) Always ask for on-board access to a direct USB plug, then run Atlantis from a non-encrypted drive volume? Ignoring all privacy issues and running the risk of exposing all my templates, addressbook etc to whoever gets hold of my stick.
Very unfortunate. Atlantis is not as widespread as MS Word, unlikey to find it installed by default. I think it is especially important for a software like this to be portable, truly portable.
MaximilianKohler
Re: Issues with portable mode
Post by MaximilianKohler »
In case anyone comes across this thread via search, this issue should be fixed now viewtopic.php?p=12236#p12236
admin wrote: Fri Aug 25, 2023 10:47 pm Atlantis Word Processor 4.2.1 (and higher) does not store its settings in the Windows Registry.
On the "Load/Save" tab of the "Tools | Options..." dialog of Atlantis you can specify where Atlantis should store all its user-specific files (including the settings).
Gavin Holt
Post by Gavin Holt »
I would really like to use AWP, it is beautiful, light, and quick. This software would be an ideal addition to my collection of portable applications - on my OneDrive. I use a batch file to always mount (subst) the OneDrive folder with the drive letter O.
My definition of a portable application is best described on the Portable Apps site [https://portableapps.com/about/what_is_ ... definition]:
A portable app is a computer program that doesn't need to be installed into Windows like traditional apps so you can carry it with you on a portable device or synced cloud folder and use on any Windows computer. When your USB flash drive, portable hard drive, or other portable device is plugged in or your cloud drive is synced, you have access to your software and personal data just as you would on your own PC. And when you unplug the device, none of your personal data is left behind.
Your definition of a portable application insists that the software is run on removable media - and therefore I cannot use it from my One Drive. I fully understand that this stops people copying and distributing your hard work without the opportunity to enforce payment.
I am not a software professional, but is there any alternative mechanism to control un-registered distribution, while allowing the more commonly accepted definition of portable software? Personally, I would not object to "call home on launch" to ensure each paid copy is only used on one PC at a time.
Kind Regards Gavin Holt
PS. Truly portable software is best distributed in zip files.
Please see the release notes for version 4.4:
https://www.atlantiswordprocessor.com/e ... _0_000.htm
Gavin Holt
Thank you for sorting this out. I will enjoy using AWP, it is beautiful, light, and quick.
Lifetime registration completed and entered for the copy on OneDrive.
Hoping the registration will follow me around?
Gavin, thanks for your support.
If you installed Atlantis "as portable" (all the Atlantis files in one folder) to your OneDrive account, this copy of Atlantis will be available on each computer connected to your OneDrive account. When using a portable copy of Atlantis, it is preferable to store the Atlantis document files under the home folder of Atlantis.
